Why is my Samsung Neo 5 using up my data when I am downloading from the net at home with my wifi turned on?
  • 2
  • Updated 2 years ago
Data charged when at home connected to net with wifi.
Photo of mar.uniat
mar.uniat
  • 190 Points 100 badge 2x thumb
  • frustrated
Posted 2 years ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,428 Points 50k badge 2x thumb
well this is interesting: samsung has its own version of apples Wi-Fi assist. Check settings, Wi-Fi. The 3 dot menu top right, advanced, tap network switch to disable. That should stop it.
Photo of Daniel Hryb
Daniel Hryb
  • 3,860 Points 3k badge 2x thumb
The feature is called Download Booster disable it if it is enabled.  It allows you to use both Wifi and Mobile data to increase your download speed
It could also be due to sending or receiving MMS (Picture or Video messages) This technically does use mobile data, however it is not counter against your data allotment
Photo of mar.uniat
mar.uniat
I checked setting, Wi-Fi, but don't see a 3 dot menu top right..?  I have a Samsung Neo 5.
I have had been unable to download a pic sent with a text message too...
It was obvious that my data was being used/charged inappropriately when I was at home, had the Wi-Fi on, and tried to download a game onto my phone.  It used up all of my data for the month, which automatically shut off the data... before the download was complete.  (this occurred sometime after getting the aforementioned text/pic that would not download)
Photo of James Greig
James Greig
  • 160 Points 100 badge 2x thumb
I too have been running into the same problem with a Blackberry with the cell data turned off and in WIFI only mode. Koodo providing no customer service.
Photo of rikkster
rikkster, Mobile Master
  • 68,330 Points 50k badge 2x thumb
On the S5 Neo, the feature is called Smart Network Switch, accessed by tapping Settings > Wi-Fi > More > Smart network switch. A window will appear with the following text: "If Smart network switch is on, your device will be connected to a mobile network automatically when the Wi-Fi connection is unstable. This may result in additional charges depending on your payment plan".
If Smart network switch is enabled, simply tap the OFF radio button to disable Smart network switch.
Photo of mar.uniat
mar.uniat
Hi, My Smart network switch was turned off.
Photo of Ranjan
Ranjan, Official Rep
  • 30,412 Points 20k badge 2x thumb
Hi Mar - if you're unsure of what's eating up your data, it might be worthwhile visiting a Koodo shop to get a free diagnostic test run on your phone. Between this and the reps guidance, you should be able to see if it's a specific setting, an app in the background, or something else entirely that's consuming your data. The Koodo shop in Chinook Centre looks to be the closest one to you.
