Why is my itunes accounts using extreme amounts of data on iphone 5s?
  • 2
  • Updated 1 year ago
My iphone 5s is using extreme amounts of cellular data.  Discovered it was coming from iTunes accounts under system services.  I'm not even using iTunes and have cellular data turned off for the app store
Photo of buddy
buddy
  • 132 Points 100 badge 2x thumb
Posted 1 year ago
  • 2
Photo of David
David, Mobile Master
  • 93,460 Points 50k badge 2x thumb
What is 'Extreme'?
Are you using iCloud services to sync or manage calendars, email, passwords, safari bookmarks or other iCloud services?
Are you streaming music, or using Apple Music?
Photo of Peter Boldic
Peter Boldic
  • 62 Points
  1. ilovethis
Photo of buddy
buddy
I used close to 1 gb in 2 days.  I'm not using icloud.  I'm not streaming music or using apple music
Photo of David
Did your phone do an update of the operating system?
Photo of buddy
buddy
No, it keeps prompting me to do the new update but I haven't yet
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
It might be "downloading" the update behind the scenes over cellular data and then prompting you to install it.
Photo of David
@titaniumtux
   That would be my guess as well.
Photo of Allan
Allan, Mobile Master
  • 62,352 Points 50k badge 2x thumb
Where did you look to find this information? Are you looking at it on your phone's data usage charts? If so that system doesn't reset so it shows you data usage from since you first got your phone. It has to be manually reset every month.
Photo of buddy
buddy
I manually reset it yesterday.  that's why I noticed where the data usage was coming from.  Never had an issue with this before and I haven't changed any settings to create this problem
Photo of buddy
buddy
Found the data usage under settings-cellular-system services
Photo of Allan
There are a bunch of little reasons why this could be happening. I would suggest looking through the apple forums and trying some of their suggestions.
Here is a place to start:
https://forums.developer.apple.com/thread/52943
Photo of buddy
buddy
I installed the new update.  Everything seems to be fine now.
Photo of Allan
Glad to hear it's all fixed! If you have any more questions just let us know!
Photo of helpmeplz
helpmeplz
  • 82 Points 75 badge 2x thumb
I've had the exact same problem except I have the newest update and my phone is still zapping data! I've scoured the internet trying to find a solution and can't. PLEASE HELP!
Photo of helpmeplz
helpmeplz
My newest billing cycle started and I had my data on for maybe a few hours and it took over 300MB out of the 700MB I have! So I shut off data until I find a solution
Photo of Allan
Did you try some of the suggestions in the link mentioned earlier?
https://forums.developer.apple.com/th...
Photo of David
300 MB is not necessarily a lot of data, especially f you are streaming or have a music subscription which is matching your music library, or updating applications.
Photo of helpmeplz
helpmeplz
Yeah I have tried all of them to no avail, it's left me really defeated and I wish I could trade in this phone for an android
Photo of Ivan
Ivan, Mobile Master
Do you have an Apple Store nearby? If you do, I'd advise you to have someone in store look at this for you.
