why is koodo charging me as long distance calls, if I have received local calls only ?
  • 2
  • Updated 2 years ago
Photo of Joel D'Lima
Joel D'Lima
Posted 2 years ago
  • 2
Photo of Mathieu
Mathieu, Mobile Master
Hi Joel,
Take a look at your e-bill, in the call log you can sea each individual call and which one you got charged for.
Joel D'Lima
I'm carefully about my plan minutes. thanks.
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
So did you get charged for all incoming calls or just the ones past 100 (if any)? Calls between 8am-5pm Mon-Fri will use up your 100 minutes whether incoming or outgoing. Also did you change your plan recently?
Joel D'Lima
Incoming calls. doesn't matter the time ( charging  me any time) But are local numbers that are included my plan... (Ontario,416.. or 647..)
Joel D'Lima
i just changed my plan around 1.5 month ago.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
IIRC, if you are on a plan with local minutes only, incoming calls received when outside your local calling area incur LD charges.
Photo of Goran
Unless your plan has unlimited talk or incoming included, your daytime minutes also count towards incoming calls
Photo of Mathieu
Where were you when the calls were received? You can only receive calls in your local calling area, where the calls come from do not matter. Your e-bill will show you the city you were in and you can see which calls counted.
Joel D'Lima
I'm in Toronto.
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Joel! If you want us to verify your bill, you can contact us on our Facebook or Twitter accounts in Private as we can't see your account here on the Community :)
