why incoming calls going straight to voicemail
  • 2
  • Updated 1 year ago
Traveling in Canada with iPhone 5. Why Incoming calls going straight to voicemail
Photo of Sandra Annesley
Sandra Annesley
  • 216 Points 100 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Hello Sandra,
Do you have do not disturb mode activated (little moon in status bar)?
Sandra Annesley
Not new customer. Incoming calls worked before. Am travelling this week so need to get calls.
Photo of Robert
You're travelling in Canada or outside? I'D say in Canada, but want to make sure...Ddi you try restarting your phone?
Photo of Dennis
Dennis, Mobile Master
  • 196,120 Points 100k badge 2x thumb
If Robert's suggestion doesnt work, try Settings>General>Reset>Reset Network settings
Warning, any wifi passwords will be lost
Photo of Dennis
Also make sure your phone app is not restricted to "only people in my contacts"
Sandra Annesley
Good idea. Checked. Not restricted.
Photo of Dennis
Are you able to call out or text successfully?
Sandra Annesley
Yes
Sandra Annesley
Yes. Was fiddling with Fitbit settings yesterday. Turned off automatic Time Zone setting to force time to set to ET. Could that have affect?
Photo of Dennis
  • 186,170 Points 100k badge 2x thumb
The time shouldnt have an effect here.
Do you have bluetooth on?  If you do, does it work when you turn it off?
Sandra Annesley
Works when turned off and when turned on. Now getting incoming calls. Now don't know what changes I made to get incoming calls, and stop going directly to voicemail!
Thanks to all for advice!
Photo of David
David, Mobile Master
  • 88,326 Points 50k badge 2x thumb
Sometimes just turning the phone off then on again fixes things!
Sandra Annesley
Another sensible idea. Thanks
