Why I'm I been charge Airtime when am not over my mins?
  • Updated 3 months ago
Photo of Karlene McGregor
Karlene McGregor
  • 90 Points 75 badge 2x thumb
Posted 3 months ago
Photo of David
David, Mobile Master
  • 91,286 Points 50k badge 2x thumb
Have you reviewed your PDF invoice, downloaded from Self-Serve? It will have all the details.
Often these charges are for long distance calls to USA or call forwarding of numbers.
Karlene McGregor
Yes I have. But as per my bill I still have 6 mins remaining in airtime.
Photo of Allan
Allan, Mobile Master
  • 58,760 Points 50k badge 2x thumb
Did you recently change plans or sign up with Koodo?
Photo of David
  • 91,176 Points 50k badge 2x thumb
Then,  if you share the content of the PDF with the comment here (less personal information) we may be able to offer more advice.
Karlene McGregor
Yes I did
Photo of Allan
I asked two things so ill answer for both.
If you just signed up look here: https://www.koodomobile.com/help/charges-explained
If you just changed plans then it will be sort of the same situation as listed above. If you switched halfway through a billing cycle everything gets prorated so you won't actually have 100min but rather have however many days left of that plans worth of minutes. (15 out of 30 days left will give you 50min)
