Why doesn’t US easy roam work? What variables play in to it not working?
  • 2
  • Updated 9 months ago
Using iPhone 7
I got the text when I entered US saying plan was activated.
Could see the carrier AT&T
Photo of Wendy
Wendy
  • feeling like I should give up in these plans that never seem to work right with Koodo. is it Koodo or do all carriers have glitches when I leave home destination.
Posted 9 months ago
  • 2
Photo of Pedro Echeverri
Pedro Echeverri
  • 112 Points 100 badge 2x thumb
it may show at&t and koodo is recognizing you are out of our network but you wont be charged until you make a call or send a text message.
Photo of Dinh
Dinh, Mobile Master
  • 41,784 Points 20k badge 2x thumb
If you turn on data roaming on your iphone7, your iPhone is properly using data from AT&T already for mail and others app. And that trigger the start of easyroam, I believe.
Photo of Wendy
Wendy
I get that part but I would rather have connection - no internet service is painful. I am trying to understand what variables play in so it doesn’t work
Photo of Wendy
Wendy
Data roaming was on - no internet connection
Photo of Dinh
Dinh, Mobile Master
Did you have the add-on easyroam on your account? (through selfserve or text ROAM to 7626)
Photo of Wendy
Wendy
Thru self serve added easy roam
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
Pull out your Sim card. Put it back in. Restart your phone. Cycle airplane mode. Let us know if it doesn't work.
Photo of Wendy
Wendy
Too late. I am back home now. What would pulling out the SIM card have done??
Photo of Dinh
Dinh, Mobile Master
Properly just trying to put the phone to restart recognizing the SIM and in that process, hopefully could clear any bugs that prevented you from easyroam.
Photo of Goran
It just helps with reconnecting sometimes. Sometimes a restart works and doesn't work. Sometimes pulling the sim card out does and doesn't work. Sometimes airplane mode does and doesn't work. You try all of them and it should make the connection work.
Photo of Wendy
Wendy
The restart I did try. On and off airplane mode was done when I was flying. So I will give SIM card a try next time.
Is this just Koodo because of their arrangements (or lack of) with US carriers!
Would the experience be better with one of the big carriers??
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Hello there,
No it has nothing to do with that
Nope, it is a local issue with your phone so there's surely a solution
Photo of Goran
Very unlikely. Koodo wouldn't get far with collecting roaming revenue if it didn't have agreements in place.
I'm not sure if AT&T is the exclusive roaming partner or not these days. They could have had issues themselves as well.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
I just wanted to add that Easy roam is exclusively a BILLING add on. It has absolutely no bearing on whether your phone is able to connect to the network. It simply makes sure you don't pay through the nose to do so.
Photo of Wendy
Wendy
Ohh ok that puts some perspective around this issue . Thank you!
