Why does my volume keep shutting off
  • Updated 7 months ago
Photo of Nath Héroux
Nath Héroux
  • 90 Points 75 badge 2x thumb
  • sad
Posted 8 months ago
Photo of Goran
Goran, Mobile Master
  • 97,798 Points 50k badge 2x thumb
Can you give more details and tell us what phone you're using?
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,908 Points 100k badge 2x thumb
Do you have do not disturb enabled for a specific time possibly
Well like Goran said can you explain a little more like when this happens and what your doing when it happens ect, that will help us identify the issue?
Nath Héroux
So every time I click on anything my volume shuts off on mute even when it's just sitting there I'm not doing anything with it it goes straight to mute
Photo of Allan
Allan, Mobile Master
  • 62,876 Points 50k badge 2x thumb
What phone are you using?
Photo of Dinh
Dinh, Mobile Master
  • 42,316 Points 20k badge 2x thumb
What phone was it? was it under warranty?
If you have a case on the phone try removing the case and see if it still occurs.
Also tap the volume down button vigorously incase there's something stuck in there or sticky around it.
If that doesn't solve the issue
Try uninstalling any apps you've downloaded right before this began occurring.
If that doesn't solve the issue back up your contacts, photos ect and perform a factory reset and set up as a fresh device.
Photo of Barb Cole
Barb Cole
  • 62 Points
I thought this phone was supposed to be simple.  Theree is no ringing when call comes in.  The voiice volume is also very low and hard to hear. I do not have a case for it, and it is usually in my purse or on the table.
Photo of Allan
Turn bluetooth off and make sure the call volume is all the way up. Most phones split their volumes into different segments. (One for notifications, one for calls, one for media, etc.)
What phone do you have Barb?
Photo of Barbara Ann Cole
Barbara Ann Cole
  • 92 Points 75 badge 2x thumb
LG ANDROID
Photo of Allan
What kind of LG? G5, G6, K4, etc.
Go on LG's website (there's somewhere on Koodo as well I believe) and download the users manual for your phone. The basics might be harder to find on YouTube but check out YouTube and search your phone model and issue and you'll find videos helping you along the way of learning your device Barbra it's an excellent source for learning anything new I use it all the time for projects I'm unsure about and it's come in handy more times than I can count so definitely worth a try.
