why does my usage summary show I phoned voicemail but I haven't and no incoming calls so why is this happening
  • Updated 4 months ago
I keep seeing my number calling voicemail which I haven't done and I don't see any incoming calls on my usage history it shows a time of 5 seconds for the call duration what is happening ?
Photo of Tracey
Tracey
  • 400 Points 250 badge 2x thumb
Posted 5 months ago
Photo of Allan
Allan, Mobile Master
  • 56,896 Points 50k badge 2x thumb
By calling voicemail do you mean you see your number? You will see your number displayed on the bill and usage summaries if you get a call from an unknown number or something similar.
Photo of Tracey
Tracey
it shows outgoing call as my number to the voicemail number and I didn't call my voicemail and it's saying the call was 5 seconds long no incoming missed calls show
Photo of Tracey
Tracey
can you tell me if my phone is off for a few days and someone sends me text messages how long will they stay on my phone unread before they delete ? i have a prepaid phone ?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,162 Points 100k badge 2x thumb
Not setting up your voicemail login does not prevent people from leaving messages. If you want to do so, setup your voicemail, then choose option 3 to manage your greetings. Then choose 4 for manage extended absence greeting. Record an extended absence greeting and you will be given the option to not accept messages. Activate this and you'll never get a voicemail again.
Photo of Brian Ramler
Brian Ramler
will this option stop my minutes from being used up? It has been explained to me by Koodo service that if I haven't checked voicemail my minutes should not be used up. I have never checked voicemail and my minutes keep disappearing. At least 10 Koodo reps and techs couldn't explain how that was possible.
Photo of Ray
Ray
  • 7,674 Points 5k badge 2x thumb
Check to see if your booster minutes (on the overview screen of prepaid self-serve) are in fact being depleted. The usage details may show minutes being used when people call your voicemail, but it should not actually be using your minutes at all.
Brian Ramler
Koodo has informed me that my phone was using an old logarithymn which was depleting my minutes even though I wasn't checking my voicemail. They informed me my phone/plan has been updated and the issue is resolved. I hope that is the case. Time will tell.
Does this sound like a valid reason to you?
Thank you for your response.
Brian
Logarithm? No. Algorithm? Quite possibly.
