Why does my phone use my data when I'm at home with WiFi turned on?
  • Updated 3 weeks ago
What is going on.
Photo of Joshua Siegert
Joshua Siegert
  • pissed off
Posted 3 weeks ago
Photo of Mats
Mats
  • 22,360 Points 20k badge 2x thumb
Why do you think this is happening? It shouldn't if you are connected to a WiFi network. Are you sure you are?
Photo of rikkster
rikkster, Mobile Master
  • 68,504 Points 50k badge 2x thumb
Can you tell us which Android phone you have?
Android version?
Have you turned off Adaptive Wi-Fi or Download Booster? This feature can switch over to mobile data when a drop in Wi-Fi signal is detected by the phone. In some cases, the feature is turned on by default from the factory. The settings for Adaptive Wi-Fi (as it's called in Android 8) is usually found in Settings > Wi-Fi > Advanced Settings - paths and/or names may differ depending on the device and Android version.
