Why can I not receive calls from Canada while in the US. Does data have to be on? Airplane mode was off.
  • Updated 3 weeks ago
iPhone 8
Photo of Greg Riihimaki
Greg Riihimaki
Posted 4 weeks ago
Photo of Dinh
Dinh, Mobile Master
  • 27,618 Points 20k badge 2x thumb
hi Greg,
Are you on a prepaid or postpaid plan?
If you are on postpaid, did you enable roaming in US?
Greg Riihimaki
I think I found the problem. My carrier setting was turned off from automatic while in the US. Would this be the cause?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 138,430 Points 100k badge 2x thumb
A monthly plan will work whether you have a roaming add on or not. It will just cost an arm and a leg to use it.
Greg Riihimaki
I’m on a monthly plan. That’s why I’m surprised that my phone didn’t pick up the call. It was an important call and I knew what time it was supposed to come so I was ready.
Photo of David
David, Mobile Master
  • 85,926 Points 50k badge 2x thumb
But, if you had not specifically selected the carrier in the local area, your phone would not ring.
Photo of Mats
Mats
  • 7,562 Points 5k badge 2x thumb
While roaming in the USA set carrier to automatic. No additional roaming add ons needed as mentioned before.
Photo of Dennis
Dennis, Mobile Master
  • 180,842 Points 100k badge 2x thumb
What happened when you tried to make an outgoing call
