why am I being charged for Data when I have disabled it on my phone? I have an android phone
Photo of Jennifer Orton-Howson
Posted 3 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,788 Points 50k badge 2x thumb
Hi Jennifer,
If you have been charged for data it is because you used data! In the settings of your phone there should be a data usage section that can tell you what app used data so you can know for next time. If data is something you never use, you can call Koodo using *611 from your Koodp phone and ask them to place a data block on your account. Doing this however, will also block MMS messages from being sent or received from your phone, so if you use picture messaging, then the data block is not the greatest of ideas.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,572 Points 100k badge 2x thumb
When you turn on data to send or recieve picture messages other apps can sync in the background as well as any widgets you have on your Homescreen such as weather.
If you go into your data usage like Mathieu said and find the apps that are taking data you can disable background data of those apps so they won't sync unless you open them. To do so tap on the app and on the next screen scroll to the bottom of the page and check off to disable background data.
Photo of Dennis
Dennis, Mobile Master
  • 177,710 Points 100k badge 2x thumb
Does it show usage on your Android Data Tracking within Settings?
