Which Samsung Note 3 is compatible with Koodo LTE? Is it the N9005? Thanks
  • 2
I am looking to purchase an unlocked Samsung Note 3 to bring over to koodo, but I don't know which model to purchase. I want to have LTE/4G capability if possible. I think it might be the model N9005? Please advise! Thanks!
Photo of Nohl Reiser
Nohl Reiser
  • 204 Points 100 badge 2x thumb
  • 2
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
I'd assume it's whatever model Telus got, unfortunately I am having issues confirming what it's model is via Google.
Nohl Reiser
Thanks Guys, I have been searching to get the exact model number but I can't find it listed anywhere...
Photo of Jorden
No problem. I do see on Telus's website that it supports the LTE bands, and since Telus owns Koodo it would be fine, just no model number.
hello, do i need to unlock the note 3 first before activating it on koodo? and im planning to go for vacay(philippines) can i use it? thank u guys
Photo of Shawn Ouellette
Shawn Ouellette
  • 324 Points 250 badge 2x thumb
I use the Note 3 on Koodo and mine is the SM-N900W8 32GB model and it works great, It is unlocked also, mine displays both the LTE / 4G depending on the location. I have used it for about 5 months and never had any issues. Going to get the Note 4 soon as it's available then sell the Note 3
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
From what I'm seeing yes the Galaxy Note 3 SM-9005 will work on Koodo's frequencies
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
Found some info on the Note 3 LTE on Samsung's UAE site.
http://www.samsung.com/ae/consumer/mo...
Nohl Reiser
So after some digging I found the model number that best fits Telus/Koodo,
Note 3 N900W8
GSM 850 / 900 / 1800 / 1900
HSPA 850 / 1700 / 1900 / 2100 @ 42 Mbps
LTE 700 / 850 / 900 / 1700 / 2100 / 2600 @ 150 Mbps
Thanks Guys
Photo of Nydern
Nydern
  • 90 Points 75 badge 2x thumb
But this version have exynos 5420
Processor and not the snapdragon 800... I was thinking all the North america version of the note 3 have the snapdragon Lte
Photo of Jonathan I
Jonathan I, Mobile Master
Yes, especially if you're traveling.
You need to unlock it before it will work on Koodo unless your buying an factory unlocked model. If you pop in your Koodo Sim it will ask for an unlock code right away and won't let you use the phone till the code is entered.
oh ok. where here in canada can i buy factory unlock? do u know? thanks
I bought my factory unlocked Galaxy Note 2 from expansys.ca maybe check them out
Photo of Note3user
Note3user
  • 60 Points
I have a note 3 SM-N900 ( from India ) it works with Telus calling works , texting works and even the data (3g only) i was wondering if the Note 3 SM-N900 would work on koodo including Data ???
please reply quick
thanks
Photo of rikkster
Koodo operates on the Telus network. You'll probably have to create a new APN so that your N3 will work correctly with Koodo.
http://help.koodomobile.com/plans-add...
