Which S7 Edge model is sold by Koodo?
  • Updated 2 years ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: positive tab mentions
Hi, I am considering using my positive tab balance to buy an S7 Edge, however I can see some places selling it unlocked AND dual sim for basically the same price, and even considerably lower if I go for a 5.1`` screen.
So in the end, there are quite a few different S7s. Would you know which one is Koodo's? Is it dual sim? Is it unlocked? It is more expensive than everywhere else, that's for sure.
The description says it's the Exynos with 5.5`` screen, so that's all I know.
Thanks.
Photo of Cristiano de Oliveira
Posted 2 years ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,262 Points 100k badge 2x thumb
SM-G935W8. It is not unlocked, nor is it dual sim. FYI, the dual sim versions of this phone do not have expandable storage, as they replace the SD slot with the second SIM card.
Photo of Goran
Goran, Mobile Master
  • 91,406 Points 50k badge 2x thumb
There is only one model of S7 Edge. They don't make a smaller or cheaper version of it. There is the regular S7 which has a 5.1" screen but no edge display. There is a dual sim model yes and it should work on Koodo. You can grab the model from the site and go to willmpyhonework.net to see if it will work. The ones that Koodo sells are not dual sim. It would be locked to Koodo. Also the going rate in Canada new is about 1000 dollars wherever you go. You can get it cheaper online depending where you get it from I suppose, but usually from outside of Canada.
You are right, the screen size is really between Edge X Non-Edge. I hadn't notice that. So sorry.
Aha, that I didn't know. Thanks, great piece of info. And if I recall correctly, Koodo charges $50 to unlock a phone, right?
Also: I haven't had those phones in my hands yet, so I apologize for such questions, but is there any other difference (build, features, slots etc) between the 5.1'' and 5.5'' models other than the screen size? Is the screen size difference really noticeable?
Thanks a million!
$35 to unlock. can't really do a direct comparison as I've only ever used the s7 edge, but the end does have a larger battery than the regular s7.
