Which phone to upgrade to? I'm using Samsung S3 at $50. p/m and that's all I can afford.
  • Updated 2 years ago
Deal offer sounds great as I've got an old Samsung S3. Now what? I also have extra storage installed. Can I remove and use in whichever new phone I go with?
Photo of Brenda Davison
Brenda Davison
  • 72 Points
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 83,356 Points 50k badge 2x thumb
Which deal are you referring to? If you're on a fairly strict budget, then I suggest going to Bestbuy to pick up a Koodo branded Moto X for 240 on tab (10 a month x 24 months). You will be able to swap your SD card storage np. Motorola has an app that lets you seamlessly transfer everything from your old phone as well to download on both phones.
Photo of Mathieu
Mathieu, Mobile Master
  • 60,788 Points 50k badge 2x thumb
Hi Brenda,
I would recommend you take a look at the following similar thread that was asked earlier today:
The additional monthly cost to you will depend how much you can pay upfront for your new phone and which one you go with.
Yes, you will be able to transfer your current micro sd card to your new phone.
