Whether or not something is wrong with the weather AP
The weather AP on my smartphone will not change. Every day it says the temperature is 48 (I use Fahrenheit) I have tried all sorts of ways to change it, with no luck. Suggestions?
Photo of Brett Canavan
Brett Canavan
  • 80 Points 75 badge 2x thumb
Photo of Chris Petersens
Chris Petersens
Did you try to reinstall the app? Or is this a stock app that came with your phone?
Brett Canavan
I have tried to re-install. It did come with the phone. It kept shutting itself off. I wasn't doing it. I would go to the app itself and turn it back on - and it wouldn't work. I have been told this is a common issue with this phone. The staff at the store where I bought it helped a few times, but are clueless now.
Chris Petersens
Is it an iphone? If yes, someone has a solution here: https://discussions.apple.com/thread/...
