Where can I get a mobile usb battery?
  • Doesn't Need an Answer
I'm trying to find a place that I can physically go to and buy a portable usb battery so I can charge my nexus 4 on the go.
Photo of Deni Makhoul
Deni Makhoul
Photo of John Burke
John Burke, Mobile Master
I use an Energizer one from EBay that takes 3 rechargable AA's. Works great with my Nexus 4.
http://www.ebay.com/itm/Energizer-Ins...
Photo of Ivan
Ivan, Mobile Master
I bought a couple of these:
http://www.ebay.ca/itm/black-2600mah-...
Served me well this summer in Europe. Would give me an ~80% battery boost on my iPhone 5.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
I know you can order a few different models from thinkgeek.com. Worth doing research there, even though you can probably buy it elsewhere for less.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
I bought one of these
http://www.powerocksusa.com
The one I got can charge my iPhone 5, 5 times before needing to be recharged, or give a good charge to my iPad if needed.
Photo of Moonmack
Moonmack
  • 4,000 Points 4k badge 2x thumb
If you are looking for a physical store have you tried Future Shop, Best Buy, Staples, or Canadian Tire? Usually you can also find something at airport shops. It may be best to check if they have them in stock before going as it seems to be a little hit and miss even within the same store but at different locations.
I bought one from Best Buy when they were discontinuing a model. For the price of the stand I got the battery charger as well. That was online, not at a physical store.
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
I use these 2 that I got a couple of months ago from Monoprice:
http://www.monoprice.com/products/pro...
I prefer the 1st one for 3 reasons:
1) It's shape makes it more portable
2) It uses the same microUSB cable as your phone
3) Dual USB outputs: One is 1A, the other is 2.1A (both push out 1A when used simultaneously)
I prefer the 2nd one for 1 reason:
1) 9000 mAh > 5000 mAh
Hope it helps!
I believe you can physically go to Monoprice, although you'd have to travel to Rancho Cucamonga first....
