Where can I view my plan options?
  • Updated 2 years ago
Photo of Mary Calver
Mary Calver
  • Confused
Posted 2 years ago
  • 203,644 Points 100k badge 2x thumb
If you log into self serve, you can view your account and options right there.
Photo of Melissa
Melissa, Employee
  • 11,708 Points 10k badge 2x thumb
Hey Mary! Are you looking to view your current plan details or other plan options? If you're looking for the details of your current plan, I suggest following the steps that Chad mentionned. If you are looking for new plan options, check them out here ->http://koo.do/1DOo8cA (make sure to select the right province, on the top right of the page). Let us know if this helps!
