Where are instructions for setting up international texting?
  • Updated 1 year ago
I have paid for international texting, it did not work.   Do I get a refund?   This is the second time this has happened during international travel, it is very frustrating.
Photo of Shirley Anne
Shirley Anne
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,682 Points 50k badge 2x thumb
You should add international voice roaming and you'll likely need to restart your phone or pop out your Sim card and back in again and restart a few more times if it won't work. Also did you confirm that you had the proper + "country code" when you were texting and connected to a local network?
Shirley Anne
Yes, I was texting to Canada.   Where are the instructions for international texting set-up located?   This is the second time I have paid for service I was NOT able to use.  It is a sad state of affairs.
Photo of Goran
http://help.koodomobile.com/coverage-...
It really is just the add-on I mentioned via self-serve add-ons to enable it.
But did you have the plus in front of the 1 + number? We're you showing up as connected roaming on your phone? Is roaming enabled in your phone settings?
Shirley Anne
It was on while I was traveling.
Shirley Anne
Will you ever have instructions for international texting posted on your website?
Photo of Goran
I provided the url for what you need, which says enabling the international voice roaming add-on and then you can use talk and text. International data roaming allows data as well. Did you ever receive texts or calls?
Photo of Lorraine Friesen
Lorraine Friesen
  • 132 Points 100 badge 2x thumb
Trying to add international voice roaming but now it says no financial data found
Photo of Josie
Josie, Employee
  • 3,962 Points 3k badge 2x thumb
Hey Lorraine, we added it for you. Can you try putting your phone on airplane mode for a few seconds to refresh settings.  Please get back to us if this it's not working for you.  Thanks in advance! I also see on your account that you recently purchased the US data, minutes/text add-on for $75 and want to confirm that you do indeed need for travelling to the US or perhaps this was purchased in error? Let us know!
