when i signed up with koodoo i bought te 60 double plan which was supposed to be 2gb data but my plan says 1gb. what is it?
Photo of Carole or Dan Hughes
Photo of Jonathan I
Jonathan I, Mobile Master
When did you get your plan? The 2GB offer was for a limited time. It was technically a rate plan change. You would have needed to switch to the "double" version of the $60 plan for it to be in effect.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,050 Points 100k badge 2x thumb
If you log into self service and go to usage. It will show you Air time, Message and Data usage.Each one tells you what your limit is.
I hope it's helps.
Photo of Curtules
  • 19,666 Points 10k badge 2x thumb
For some weird reason the promotional 2GB data plan doesn't list the data as 2GB, instead it lists 1GB twice.
Is that what you see?
Photo of Mayumi
I just checked my account and it said 200mb.
I had my plan when koodo had a double min and data.
Photo of John Lee
John Lee
  • 36,704 Points 20k badge 2x thumb
The change should be instant but I guess you can try again in a few days. If it shows 1GB, then you might want to try calling Customer Service to ensure that your plan is the promotional one. You should be able to check however by seeing if your plan is named "Double Minutes/Double Data" or something like that.
Photo of bonita
  • 522 Points 500 badge 2x thumb
It shows up as 1GB twice on my double 60 plan too
Photo of Reggie Baker
Reggie Baker
  • 92 Points 75 badge 2x thumb
signed up to $60/month plan. My bill is $89+ - WTF??
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Is this your first bill?
If so, there would be what's called proration on that first bill to cover the X amount of days until the cycle ended then the month in advance.
I totally understand if you are unable to see the details of the bill online as there is an issue downloading the bills.
