When I access my voice mail using my koodo phone am I using up my anytime minutes?My plan is 'canada wide talk and text 20'
Wondering is I'm charged minutes when I access voice mail using my koodo phone?
Photo of Douglas John Chambers
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Yes, I believe it will use your any time minutes. To avoid using your airtime, you can check your VM from a landline or check it when you have your unlimited “evenings/weekends" time. :)
Photo of Marcel in O-Town
Marcel in O-Town
  • 3,722 Points 3k badge 2x thumb
if you call from your cell phone, yes it will use minutes. As Ken stated, call from a landline (or someone else's cell phone :-)
Photo of PZABOY
PZABOY
  • 5,142 Points 5k badge 2x thumb
To check your VM from a landline so you can avoid usage charges keep in mind you have to press " * " followed by your password.
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
yes , press the " * " (star key) as soon as you hear the gretting message. The system will then ask you your password !
Photo of Dennis
Dennis, Mobile Master
To clarify, to access voicemail from a land line you have to first call your cell, then press the " * " key when you hear your voicemail greeting
