when will nexus 5 devices get Android Lollipop OTA update?
  • 6
Still waiting for lollipop on my koodo nexus 5
Photo of Gary Williams
Gary Williams
  • 6
Photo of Sophia
Sophia, Mobile Master
As far as I know, it is Google that updates the device, Gary. Hang in tight, they started to roll it out today but as always, they don't want to hog their network and won't update them all at once!
Photo of Ernie MacDonald
Ernie MacDonald
  • 594 Points 500 badge 2x thumb
I just downloaded and installed the factory image from google!!!!
Gary Williams
Thanks Sophia, I am trying to be patient but it is now 3 more days and still no update. Manual loading the factory image is not appealing to me :-)
Photo of Z Gates
Z Gates
  • 386 Points 250 badge 2x thumb
Got it on my Nexus 4 yesterday.
Photo of Devinder Singh
Devinder Singh
  • 60 Points
My friend is with Rogers and he got the update today. Not me :(
Photo of Phyllis Skrzyniak
Phyllis Skrzyniak
  • 62 Points
My husband got his update from virgin yesterday
Photo of KMT
KMT
  • 126 Points 100 badge 2x thumb
I got my update today, I am using Koodo nexus 5.
Photo of Daniel Migneault
Daniel Migneault
  • 92 Points 75 badge 2x thumb
How come you got the update? i'm with koodo and my nexus 5 is still with
kit-kat????
Thanks for your answer.
Photo of Trace
Trace
  • 414 Points 250 badge 2x thumb
It has nothing to do with your cell service provide. Google rolls the update out in batches over a period of 2 -3 weeks while watching for any problems.
Patience, it will come or as suggested, do the update yourself.
Photo of keith
keith
  • 82 Points 75 badge 2x thumb
It shouldn't have anything to do with your Carrier but apparently it may. Refer to https://support.google.com/playeditio... where Google has added the following text recently: "Based on your carrier, it may take longer than two weeks after release to get an update."
This is very annoying.
I still have not gotten the update and my phone can only call out and receive calls and texts in. I can't search the net or text anyone. So not happy with this, feels like I am paying for a useless piece of technology.
Daniel Migneault
Lucky you are, my koodo nexus 5 is still with kit-kat???
Photo of Cameron
Cameron
  • 922 Points 500 badge 2x thumb
You can manually download it. Just go to YouTube and check out android authorities video on the process of how to get it installed. Anyone can get it now without waiting any longer
Daniel Migneault
But will that affect further updates?
Photo of Justin Quintal
Justin Quintal
  • 80 Points 75 badge 2x thumb
If your mobile language is set on french-canadian, and Lollipop is installed, it will do a HUGE glitch when it's plugged in to a charger. Google has acknowledged it and a fix will be out soon (i hope!)
Daniel Migneault
You are absolutely right, i'm facing that exact problem, I must have my phone shut before charging!
Photo of Gary Jones
Gary Jones
  • 90 Points 75 badge 2x thumb
Koodo sent me a replacement phone which updated automatically but my original Nexxus 5 is still not getting the update. How can I get it because I need to return the replacement phone.
Photo of Echo
Echo
  • 192 Points 100 badge 2x thumb
My mobile data doesn't work after lolipop update. Checked APN settings and everythign seems to be fine, same profile as kit kat .
This is week 2 without data :'(
Justin Quintal
You can flash the firmware on it... But keep in mind that you also need to backup your phone on your computer. Using the official factory images, you can follow the instructions at this official site, https://developers.google.com/android... find the firmware for your device, you'll also find old firmware, follow the instructions on the site,then you can fix it yourself... If it doesn't work, you can also go back to your older firmware :)
Photo of Josef Izchaki
Josef Izchaki
  • 280 Points 250 badge 2x thumb
so it makes sense that i still didn't get the 5.0 lollipop update?
Photo of Thomas McMahon
Thomas McMahon
  • 60 Points
Yea I'm still waiting as well
Josef Izchaki
I see, so it's not only me.
Photo of R. Reaper
R. Reaper
  • 84 Points 75 badge 2x thumb
Have you received the update yet?
Josef Izchaki
no unfortunately
Photo of Caseng Zhang
Caseng Zhang
still waiting here as well...sigh
Photo of John Pereira
John Pereira
  • 210 Points 100 badge 2x thumb
Just upgraded to the nexus 5 today. The girl at the koodo booth said that the new update would be available. So far however im still on kitkat and lollipop isn't available.
Justin Quintal
I updated mine manually by flashing the new firmware image.
Photo of R. Reaper
R. Reaper
I have a nexus 5 , still running 4.4.4. No lolipop update here either. I check 5 times a day and have tried every trick but still no luck.
Koodo and Google just released it for the Nexus 5. You "Should" have it by the 25th.
Caseng Zhang
thank god. thanks for the reply!
Photo of Phenom
Phenom
  • 60 Points
Geez what's the hurry with the update, people act like their phone won't work without it
