When is my plan over?
  • Updated 4 weeks ago
2 yrs
Photo of Don Foucault
Don Foucault
Posted 4 weeks ago
Photo of TJ Smith
TJ Smith
  • 4,360 Points 4k badge 2x thumb
Hello Don,
there's no "term" with Koodo; the TAB repayment of your device is 24 months.
Once you're done the service plan continue but your bill will be reduced by the TAB amount.
Exp: $60 plan + $15 TAB = $75 + taxes.
after 2 years: $60 plan + $0 TAB = $60 +taxes
You can change the "plan" part anytime you want, i.e. $60 was 4GB but now there's a 6GB plan for $50. You just switch to theĀ new plan and your monthly bill will be adjusted accordingly.
Cheers mate
Photo of Dennis
Dennis, Mobile Master
Also as long as you dont change your plan, you can keep it for as long as you want (for now)
