When I try to turn on "Data Notification" via Self Serve> Usage> Data notification it never stays saved as "On"?
  • 3
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 mention
Okay so there is an option to get a data notification via text on the Serve Serve Section. You go to Usage > Data Notification and turn it on and click "Update". Whenever I do this it never saves the option as "on". I want this option to stay on and remain on but it won't save. Can someone fix this for me? Or do I need to call in to fix this? Thanks!
Photo of Brandon Horton
Brandon Horton
  • 200 Points 100 badge 2x thumb
  • 3
Photo of Dennis
Dennis, Mobile Master
  • 187,350 Points 100k badge 2x thumb
Try clearing your cookies.
If that doesnt work You will have to call in and see if they can set it for you if it is not working on your self serve. *611 on your koodo cell... it's a free call
