What does USSD code running mean on my Moto G phone?
  • 2
I was trying to check my voicemail and when I pressed 1 I got the message "USSD code running." What does this mean and why can't I check my voicemail?
Photo of Tania Schumacher
Tania Schumacher
  • 2
Photo of Sophia
Sophia, Mobile Master
Hi Tania,
Usually you get that message when you run a special code, such as *21 to forward your number. Did you long press the 1 to check your voicemail? Try rebooting your phone too and then see if it works :)
Photo of Schumi
Schumi
  • 114 Points 100 badge 2x thumb
Thanks Sophia! I did press the 1 a long time and must have caused that message to pop up. I did turn off the phone and rebooted it and that worked to clear that message and let me check my voice mail the right way. Now I know how to check my voice mail and that is to call my cell number with the 1 in front of it. Thanks for your help.
