What are the APN and MMS settings for a Nokia 920 on Koodo
Unlocked my Lumia 920 from Rogers - complicated - and now I need to allow data and mms.
Does anyone have the settings to manually enter into the phone?
Thanks
Photo of Stephen Pâté
Stephen Pâté
  • 142 Points 100 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://aliasredirect.net/proxy/koodo/ mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: leave blank
Photo of Boolanger
Boolanger
  • 9,234 Points 5k badge 2x thumb
I've got a unlocked 920 myself. You'll still probably have issues after setting the apn info. Your best bet is to go to the store and grab the app lumia pusher. This app has direct links to Nokia apps that you can't search the store for normally.
In the app go to the access point link and download the access point app.
Once the app is installed you'll find it under your phones settings. Then just choose Koodo as your network and the app will guide you.
Photo of Boolanger
Boolanger
Oh and you have to delete your current apn info
Stephen Pâté
Thanks for the reply Timo
The mms apn data does not match the screen fields
"MMSC: http://aliasredirect.net/proxy/koodo/ mmsc
MMS Port: 80
MCC: 302
MNC: 220
APN type: leave blank "
From the reply is this it?
APN sp.koodo.net
User name / password (blank)
WAP gateway URL -?
WAP gateway port 80 ?
MMSC url http://aliasredirect.net/proxy/koodo/ mmsc
Stephen Pâté
Nokia Pusher has an icon for Nokia Network+ but it does not install any software.
Is there a trick?
Photo of Boolanger
Boolanger
Well the access point app installs and then can be found under the OS settings
Photo of Ivan
Ivan, Mobile Master
Delete any APN settings you've entered manually.
Go to: http://julip.co/2012/12/lumia-810-cha...
Use Bing Vision (eye icon in the search app) to scan the QR code.
It will install the Access Point app in your menu (not on the app list). You will then be able to choose Koodo. Tethering will now work, unsure about MMS. I used to have a 920 and this is how I got it up and running.
Photo of Boolanger
Boolanger
MMS should work as it works for me with the access point.
Photo of Ivan
Ivan, Mobile Master
Thanks for the confirmation. I don't send MMS so I couldn't say for sure.
Photo of Devon Parsons
Devon Parsons
  • 60 Points
MMS works also! Thanks for the info!
Photo of Ivan
Ivan, Mobile Master
Perfect. Happy to help.
Photo of AHT
AHT
I followed said instructions and now have access point and have changed selection from Telus to Koodo but alas I am still not able to sync my Hotmail as I need the correct server to point to any thoughts ...
I get error code80072EFE
Assuming data is now working, use thes instructions to setup a hotmail account:
http://www.nokia.com/us-en/support/fa...
Photo of Ivan
Ivan, Mobile Master
I've gotten a similar issue with one of my Microsoft accounts. I had to remove it and re-add it twice before this resolved itself on mu Lumia 928.
Other things requiring data work, right?
Photo of Evan Samms
Evan Samms
  • 60 Points
Are you running a 928 on koodos network Ivan? I want to buy one but don't know definitively that it works..
Photo of AHT
AHT
I just deleted my account and reset with a new one and it is working all is well thanks everyone for the help.
