what is Unlimited Canada-wide anytime minutes ? How many minutes do I have for the month for 8 am to 5 pm?
  • Updated 3 weeks ago
My current plan has 500 minutes. I am looking at switching to a plan that has Unlimited Canada-wide anytime minutes? How many minutes do I have to call between 8 am to 5 pm.
Photo of Kienzle Mody
Kienzle Mody
  • 80 Points 75 badge 2x thumb
Posted 3 weeks ago
Photo of dirk
dirk
  • 372 Points 250 badge 2x thumb
All of them. It's an unlimited minutes plan.
Photo of Allan
Allan, Mobile Master
  • 62,906 Points 50k badge 2x thumb
Your current plan would be 500min for calls between 8am-5pm and unlimited minutes between 5pm-8am.
Photo of Goran
Goran, Mobile Master
  • 97,868 Points 50k badge 2x thumb
Keep in mind that when you switched tour plan is prorated. So the part of your billing cycle where you have 500 minutes will be less as a result. For example if you switched 15 days in you would have 15/30 * 500 = 250 minutes of daytime. So if you used 300 in those 15 days you would incur 50 minutes of overage charges.
Photo of David
David, Mobile Master
  • 93,960 Points 50k badge 2x thumb
And, there is an unlimited minutes add-on available through self-serve, which can be purchased to avoid the additional overage charges, should you find it necessary to use more than your allotted minutes.
Kienzle Mody
my bill just got generated and I have not used those minutes 500 minutes in my current plan. So just to understand currently, under my new plan, I have "unlinited minutes" for 8 am to 5 pm correct?
Photo of Allan
If you have a plan with 500min that means you have 500min between 8am-5pm and unlimited from 5pm-8am.
If you have a plan with unlimited minutes then you have unlimited minutes no matter when you call.
