What is the difference between $3 a month Intl. long distance and $10 a month
For calling the U.S. what is the advantage of the $3 a month vs. $10 a month if they both provide .05 per minute? What is the $10 unlimited and how does it work?
Photo of Kim Nau
Kim Nau
Photo of Jonathan I
Jonathan I, Mobile Master
The $10 feature isn't 5 cents/minute, it's unlimited U.S minutes. The $3 add on gives you the 5 cents/minute rate.
Photo of Kim Nau
Kim Nau
Thank you Jonathan. Am I right in understanding that for the $10 Add will give me unlimited minutes to the U.S. and that it doesn't deduct from my booster plan minutes?
Photo of Dennis
Dennis, Mobile Master
  • 195,954 Points 100k badge 2x thumb
If you are on prepaid you cannot get the add-ons.
The add-ons are for monthly postpaid plans
Photo of Robert
Robert, Mobile Master
  • 106,744 Points 100k badge 2x thumb
Are you on prepaid? If you are, this isn't available to prepiaid, only to postpaid customers
On postpaid, if you have an unlimited plan, yes it will not deduct from your minutes. If on another "limited" plan, it will deduct from your minutes!
