what is international voice roaming
  • Updated 2 years ago
I would like to know what is international voice roaming and what does it give me.
Photo of John Dudley
John Dudley
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
It's an add-on which lets you make calls whenever you go outside of the country. Without this, you will not be able to make calls in the US for example.
Photo of BobTheElectrician
BobTheElectrician
  • 66,214 Points 50k badge 2x thumb
I believe you do get service in the US on post-paid without the international add-ons, unless something has changed recently.
Every now and then some people near the border get an unwanted roaming charge because their phone accidentally latched onto a stronger US tower.
If you don't allow international roaming on self-serve, you will not connect with any tower outside of country code 1 (US & Canada), so it's very important to activate before heading overseas.
I believe the international features are not activated by default in order to prevent some really unpleasant $urprise$: you can rack up big bills at $1.50-$2.50 per minute and $5-$10 per MB. So it's definitely best to consider a roaming package or unlocking and using a local SIM. Expand the Travelling outside the US link:
http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
Photo of Anna
Anna
  • 6,126 Points 5k badge 2x thumb
You're correct Bob! The international voice roaming feature is not needed to have service in the US.
Photo of Dennis
Dennis, Mobile Master
  • 196,100 Points 100k badge 2x thumb
