What happened to roaming plans other than Easy Roam?
  • Updated 2 months ago
Are the text and talk roaming plans for the US still available, to is the only one now the Easyroam plan?
Photo of Roamer
Roamer
Posted 7 months ago
Photo of Allan
Allan, Mobile Master
  • 56,966 Points 50k badge 2x thumb
Just the easyroam add on is available to add via self serve.
Photo of Rick MacEachren
Rick MacEachren
  • 60 Points
I think your company is no better than the rest of the phone service providers. You found another way to stick it to your customers. You should be ashamed of yourselves. You took the time to separate yourselves from the big providers but as how it goes. Its all about money to hell with your customers. Rick
Photo of Goran
Goran, Mobile Master
  • 90,960 Points 50k badge 2x thumb
It works better for data but not for occasional talk and text. I don't like that Koodo opted to also remove all the US packages but thems the breaks. You'll see a lot of us here disagreed with it.
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
The old US roaming add-ons are still available through customer service but only the 30 day ones may only be available and not the 3 or 10 days ones. Which one do you normally take when you visit the US? Perhaps the new Easy Roam add on is better.
Photo of Roamer
Roamer
I’ve mostly used the 10day add on in the past. My next trip will be longer.
How would I access the old plans?
It’ll be very disappointing if there is no option to use the old plans Easyroam is excessively expensive for those of us that can get by with texting and need little data or phone while traveling. Definitely a step in the wrong direction for Koodo customer service and loyalty.
Photo of Susita Lolita
Susita Lolita
  • 60 Points
I totally agree with you. Koodo got greedy and has removed those convenient U.S. roaming packages with Easy Roam.....so one text to my husband when my plane lands will cost me $7!! I'll be soon looking for another provider.
Photo of Sophia
Sophia, Mobile Master
Susita, whereas I don't disagree with you that Koodo got greedy, you do not HAVE to enable Easy Roam. You can leave the add-on off and just pay the going international rate for one text message... which will definitely cost you less than $7.
Photo of Erwin
Erwin
To be fair, for people who use their phone minimally and only for emergencies, it probably is not a good deal for them to use Easy Roam. But for the rest of us who use a normal amount of data, etc. It is a competitively good deal. This is the same rate as other carrier who has it for years.
I use KnowRoaming travelling outside Canada and it costs me $7.99 USD a day to have unlimited 3G data, no calling and no text included, and they cap the data usage then it slows down to dial up speeds. I then have to add a $3 call forwarding because the last I didn’t have this add-on, it cost me $90. Once Koodo launched Easy Roam, I immediately cancelled my KnowRoaming. For me and my friends, it is an amazing deal, more countries supported compared to other carrier for the same price. As well as, it is more convenient to not have to log-in to an app and activate my KnowRoaming when I land. Which can be stressful, as I have to fill up forms and try to make my phone pick-up a compatible KnowRoaming network.
Like I mentioned in the beginning, it is not for everyone. But there are workarounds, if you are looking for minimal usage. Maybe a local prepaid sim in that country could save more $$ or use KnowRoaming or other roaming sims out there that you can buy in Canada.
Photo of Roamer
Roamer
On the positive side, easyroam works well for some.
However, on the greedy side, why couldn’t the other roaming options be left in place to give a more economical option for those of us on a tighter budget that can get by with less service?
Koodo, are you listening to this discussion?
Photo of Erwin
Erwin
I read somewhere that it is left out because Koodo finds that there is more value with Easy Roam. However, if we can keep the chatter about keeping the old plans, maybe Koodo will end up bringing those back.
Photo of Richard Pattie
Richard Pattie
  • 60 Points
Real rip-off. We have no data on our plans and the talk and text add on was perfect. I used to really like Koodo and recommended them to my friends. May have to look at another provider now.
Photo of Goran
  • 90,880 Points 50k badge 2x thumb
Sorry what's the problem? What are you looking for?
Photo of Erwin
Erwin
Hi Richard,
The old US Roaming packages are still available through customer service. Koodo now matches other carriers roaming package.
