what does International Data Roaming add on mean and include?
  • Updated 1 year ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: "roaming" AND "bundle"
What I can get the International Data Roaming for $0. What does it mean and what does it include? I also have International Voice Roaming what does that mean and include?
Photo of Louie Sanseverino
Louie Sanseverino
  • 72 Points
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 50,736 Points 50k badge 2x thumb
These add ons just allow you to connect with cell phone networks while roaming internationally. You can choose to remove them if you want but they do no harm and are useful to have on your plan so you don't have to worry about adding them later if you need to.
Photo of titaniumtux
  • 12,892 Points 10k badge 2x thumb
The $0 international roaming enables connecting to towers outside of Canada. The roaming connection itself and incoming SMS are free. It's your usega that'll ring you a bill. Incoming or outgoing calls, outgoing SMS and data usage will charge you. Once you have the $0 international roaming added to your Koodo line, you can add a roaming pkg to your line when you plan a trip.
A more cost-effective alternative would be to get your phone unlocked, then grab a local, pre-paid sim card at your destination country. If it's too tricky to get a local sim card at your destination (language barrier, ID requirements for activation, etc.) you can look into pre-paid roaming sim cards to use with an unlocked phone.
