what are those data charges from midnight to 5:00 a.m. when I'm asleep?
  • Updated 2 years ago
Photo of Gracie Post
Gracie Post
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of jasper
jasper
  • 588 Points 500 badge 2x thumb
Without seeing a copy of your usage it would be hard to tell you but different apps do use data throughout the day and night including updating depending on how it is set or refreshing. You can turn off data on your phone or make sure you are connected to WiFi. You can also check in settings on your phone usually the data usage to see what is using the data on your phone.
Gracie Post
Thanks, Jasper!  I appreciate your prompt reply!
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
There should also be a Sync feature somewhere on your phone that lets you choose which network (wifi or data) your updates get done on. Which could help even when your out and about not getting unnecessary data charges.
