what are my phone options if I am going to Europe? How much would it cost to make calls there? to send text messages?
I'm going to be traveling in France and Italy. How much would it cost to send text messages while I am there? How much would it cost to make a phone call? whether it is to a European number or a Canadian one.
Photo of Emilie Alice
Emilie Alice
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of David
David, Mobile Master
  • 88,964 Points 50k badge 2x thumb
Information about international travel including setup of your phone & rates can be found at this link: http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Emilie,
The best option if you plan to use your phone often in those countries would be to get your phone unlocked for 35$ from Koodo directly. You can then get a pay as you go plan from one of the local providers which will cost you a lot less then Koodo's pay per use roaming.
Hope this helps!
