web site awkward and unusable
  • Doesn't Need an Answer
I can't give praise for your web site. It is awkward to use and not very functional. I recommend that you try using from a customers viewpoint.I particularly find viewing my usage history barely usable.
Photo of Brad Bergstrom
Brad Bergstrom
  • 90 Points 75 badge 2x thumb
Photo of Chris Petersens
Chris Petersens
Why don't you use their app for usage? That way you can see it on the go instead of waiting to get to computer. Just curious.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,262 Points 100k badge 2x thumb
Can't say I agree with you. I've used it from the customer's viewpoint and found everything logically arranged and easy to use.
Photo of Sophia
Sophia, Mobile Master
What would you suggest should be better, Brad?
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
I find it works very well.
