Wanting to switch phones and to medium tab
I want to upgrade my phone. I have a charge on my tab i need to pay off first. I want to get a Samsung GalaxyNote II, and on a medium tab, which is $100. I have the $55plan, that was offered for just Mb And SK. When i go to get this phone in the next month, can i keep this plan, i noticed its not offered anymore. Thank you for the person who helps me out!
Photo of Audrey Henkel
Audrey Henkel
  • 344 Points 250 badge 2x thumb
Audrey Henkel
Oh forgot to also say Do i have to pay off the $100 i owe on the $150 tab, i have at the moment? Thanks again for your help.
Photo of Daniel Kim
Daniel Kim, Mobile Master
Yes you can keep your plan since it is over $30 and yep you have to pay the 100 you owe before you can upgrade :)
Audrey Henkel
Thank you Daniel! you have been a great help!
Photo of sunfire 231
sunfire 231
I to would like to get the Note 2 but was told I must change my plan.
Right now I am on the $15 plan with $5 unlimited text and $5 data bringing it to $25 a month. I do not use voice as I am hearing impaired so this plan is great for me.
Is there a way I can do this? I currently have a $60 tab and I will pay it off before getting the note.
Photo of Jonathan I
Jonathan I, Mobile Master
Yup, that's how it goes. So at this point you can get the Note II on Tab S for 200 and keep your plan the way it is or get it for 50 but go on the $29 + 5. You're paying an extra 9 bucks a month * 24 = 216, so that's overall $66 more than paying the 200 and staying with Tab S...
sunfire 231
That makes total sense when you put it that way! Does the $29 plan have any data?
Photo of Daniel Kim
It has pay-per use data for $7.50/50mb which is not very good if you use data frequently.
Photo of Jonathan I
It doesn't, no. It's $7.50 per 50MB you use, which is pretty bad to be honest, so bite the bullet and go on Tab S for 200. You might even be able to trade in your old phone for some credit towards that.
sunfire 231
Yes that is alot! I think I will go for the small tab! I will drop by tomorrow and see what I can get for my phone. Thanks so much for all your help!
