Wanting a new phone, same SIM card and plan?
I currently have an IPhone 4S with a prepaid $15 base plan. I'm in need of a new phone, would I be able I purchase any unlocked phone and put my current SIM card into it and continue the same phone plan? Also, if I take my SIM card out ft current 4s, is it locked to Koodo or unlocked? Thanks
Photo of Carmen
Carmen
  • 450 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
You can use any unlocked Koodo compatible phone, just put Sim in and away you go on the same plan.
If your Sim doesn't fit in the new phone, you can purchase a new SIM for the same plan for $5 at a Koodo Kiosk.
Your iphone 4S would still be locked to Koodo.
Photo of Spence
Spence
No, after the 4s the Sim was changed to a Nano Sim, So all iPhone from the iPhone 5 and newer use a nano Sim.
But like I said, a new Sim is only $5
Photo of Melissa
Melissa
  • 3,184 Points 3k badge 2x thumb
New sims for prepaid are 20 bucks I believe the post paid ones are 5.
Photo of Carmen
Carmen
do I just ask the Kiosk workers to purchase a nano sim with my same plan even if I don't have my new iPhone yet? Would I have to take out my current Sim to show them? Thanks so much :$
Photo of Mathieu
Mathieu, Mobile Master
Just go to the Kiosk and ask them for a pre-paid nano SIM card. They should even be able to transfer your account to the new card.
Photo of Spence
Spence
oops ,  sorry Carmen,   didn't notice you said prepaid.
Prepaid Sims are $20
