VPN setting not working with my LG-P500h.
  • Updated 11 months ago
VPN setting not working with my LG-P500h. Set Koodo, sp.koodo.com, http://alias... etc. Data activated. Tried closing and reopening phone. Nothing is working. Please help.
Photo of Eric Trottier
Eric Trottier
  • 134 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Allan
Allan, Mobile Master
  • 57,126 Points 50k badge 2x thumb
I don't believe that phone is compatible with Koodo. It has very limited 3G bands and 2G bands (which Koodo no longer supports).
Photo of Allan
@Paul Oh okay. From what I was reading the 850 was a gsm band and it didnt have an 850 umts band. You're probably right though as the phone is working for the OP with everything but data.
Eric Trottier
I hadn't upgraded to Gingerbread. Now I have. Still same problem. Did everything: data enabled, settings to the letter, restarted, pulled out SIM card, etc. Now I have multiple APN Koodo Mobile settings and I can't delete them. I tried one after the other, they all have the same settings & they all won't work!
Photo of Goran
Goran, Mobile Master
  • 91,406 Points 50k badge 2x thumb
Try factory resetting your phone. Be sure to back it up. Not sure why it's being difficult. I bought one for my mom when it came out and therefore never were any issues.
Eric Trottier
Just did. Isn't working either. Thanks for the advice.
Eric Trottier
The Internet was blocked by the company. It's working fine now.
Thank you all for your help!
Photo of Goran
Are you sure that you mean VPN? There are no specific Koodo settings for that as Koodo doesn't specifically do VPN. Do you mean APN?
Eric Trottier
Yes, I meant APN.
