Volume keeps turning down
  • Updated 2 years ago
Photo of Ernest Niedermayer
Ernest Niedermayer
  • 232 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
  • 142,964 Points 100k badge 2x thumb
What phone? What app? When does it happen? If you want some help, be more specific please...
Ernest Niedermayer
android s5- app don't know-over niteĀ
Ernest Niedermayer
APP- Sounds and Notification
Ernest Niedermayer
no have no such equipment or program
Photo of Sophia
  • 142,934 Points 100k badge 2x thumb
I'm still thinking it must be some rogue app causing it... One that is triggered during the night. I suggest you try the factory reset and then put your apps back one a day, see if any of them mingles with your volume settings.
Ernest Niedermayer
could you explain to me a factory reset
Photo of rikkster
rikkster, Mobile Master
  • 68,218 Points 50k badge 2x thumb
A factory reset will erase all user content from the phone, excluding content stored on an SD card, (if applicable). If there's a problematic app, whether it's a system or user app causing the volume issue, a factory reset should restore all settings to factory default. Video below shows both hardware and software factory reset methods.
https://www.youtube.com/watch?v=kqm0u...
Ernest Niedermayer
Happy to report that after the reset the volume is working fine. thank you all for your help
