voicemail issues
When setting up the voicemail I had to use the koodo one because of the noises when trying to set up my greeting. Now when I listened to the first message left, I get the same noise, like feedback, so I can barely make out the message.
I have tried the recorder on the phone and it records and plays fine. I also can talk on the phone without the noise. Not sure what is going on. It is a 3 year old LG banter.
Any ideas??
Photo of Christine
Christine
  • 210 Points 100 badge 2x thumb
Photo of Myke
Myke
It sounds like it's an issue with either the Microphone or the speaker.
Photo of Christine
Christine
I used the recorder on the phone and that worked perfectly for recording and playback so I don't think the microphone or speaker is an issue.
Photo of Myke
Myke
Well it's not an issue with the Voicemail, because it records from the microphone. This is why I believe it's an issue with the phone. A service can't produce feedback noise. Feedback noise is always hardware related.
At any rate, your phone is way beyond the warranty options, so I would suggest looking at getting a new phone.
Photo of Christine
Christine
I only get this noise with the recorded message that was left on the voicemail and when I tried to record my name for the greeting. Other then that the phone works perfectly. The microphone and speaker work perfectly with everything else.
Photo of Christine
Christine
thank you.
Photo of Christine
Christine
not so easy to just go out and get a new phone when money is very tight, but thanks for the help.
Photo of Myke
Myke
Yeah, understandable. You can always use your tab.
Photo of Christine
Christine
just sucks, its a perfectly good phone except for the voicemail issue. I was hoping it was just some setting that needed changing.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Ya I just read by 2015 which I took as it happening some time in 2014.
