Voicemail notification problems
  • Updated 12 months ago
Since a couple of months, I have 2 problems with my voicemail.
1-Notifications: even after listening and saving or deleting all my new voicemails, the notification icon stays on my phone.
2-Once in a while, a saved message will pop back as new when I call my voicemail.
I have a moto x Play
Any ideas on how to solve this?
Photo of Nicolas Turcotte
Nicolas Turcotte
  • 170 Points 100 badge 2x thumb
Posted 12 months ago
Photo of David
David, Mobile Master
  • 89,034 Points 50k badge 2x thumb
Have you turned your data off?
Nicolas Turcotte
Data are on. I do turn it off sometimes....but for example not in th elast week, and the toggling problem keeps occuring.
Photo of Robert
Robert, Mobile Master
  • 103,714 Points 100k badge 2x thumb
Hello Nicolas,
Data on is needed in order to receive those notifications. Do if you turn it off, it might affect those notifications.
Nicolas Turcotte
Ok, it might be that, i will keep an eye on this relation between my turning off of the data and the notification problem. What about messages that are saved and become new again within my voicemails? any ideas?
Thansk all for your help
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
This has not been my experience, even with Koodo. Voicemail notification works even with data blocked. I also happen to have a Moto X Play from Koodo, never had any issues with voicemail notification.
Here's my 2c:
  1. Make sure there are no 3rd party phone apps running (example Fongo). If so, you might have voicemail messages in those apps, then clear that out.
  2. Try rebooting the phone (standard troubleshooting).
  3. Call your cellphone from another cellphone or landline, leave yourself a message, then from your cellphone, access that message and delete it.
For messages that are saved and then flip into new messages, that'll likely require talking to tech support. I highly recommend using a call recording app to record your saved messages (save 'em to MP3), then delete them from your Koodo voicemail.
Hope that helps.
