Voicemail not working
  • Updated 12 months ago
I recently noticed that ive been paying for voicemail with my plan that which orignally worked fine but now for some reason it stopped working a couple months back and I have no idea why but it's still listed as being included in my plan.
Photo of Mike McMillan
Mike McMillan
Posted 12 months ago
Photo of Sophia
Sophia, Mobile Master
Can you access voicemail by long pressing the number 1?
Photo of Bernard
Bernard, Official Rep
  • 75,650 Points 50k badge 2x thumb
Mike, when you log in online to see your plan, do you see voicemail listed there? You shouldn't as you are on an older plan that includes call display, not voicemail. You did have visual voicemail but you seemed to have dropped that back in December via self serve.
Mike McMillan
That's the weird thing, since the day I started with koodo I had voicemail. Then several years later I had an iPhone and they offered me visual voicemail so I took that. Then I forgot to get rid of visual voicemail when I switched from my iPhone to Samsung so I did that around December and I think that is when my voicemail stopped working. But I figured that would be just my visual voicemail I was cancelling not voicemail all together seeing how I've had it for many years prior to that with the same plan at no extra cost.
Photo of David
David, Mobile Master
  • 89,320 Points 50k badge 2x thumb
Seems like your plan does not include Voicemail. Specifically adding VVM allowed the use of voicemail, but when you cancelled VVM, you fell back to the default of the plan, described by Bernard earlier, as having no voicemail.  IF this is important to you, you could change plans to a newer one with VM, or use a third-party VM.
Photo of Bernard
Hmmmm...not sure how to explain that. You could always switch to a current plan like the one below. Unlimited minutes, call display, voicemail included, and 3gb of shock-free-data.
The plan you have did not have voicemail included in it. This is what it does:
