voicemail not working.
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 mention
Hi. i just changed my phone number 2 days ago because i moved to a new city and now i cant access my voicemail from my previous number nor can i create a new voicemail for my new number, please help me for it is of great importance that i have my voice mail operational. thank you.
Photo of Kevin
Kevin
Posted 3 years ago
Photo of Sophia
Sophia, Mobile Master
Hi Kevin,
You may need to contact Koodo directly to reset your voicemail, give them a call at 611 and they'll be able to sort it for you :)
Photo of Eugene
Eugene
  • 1,748 Points 1k badge 2x thumb
Hi, Kevin
First off, make sure that your phone's voicemail is actually turned on.
In Dialer, tap Menu/Settings/Call Settings/Voicemail/Setup, and make sure the correct number is there. After, open the Dialer app, tap Menu>Settings>Call Settings>Voicemail, and make sure the Sound is set to a tone that you like:)
However, if you have an apple device, try these steps.
Restart your iPhone.
Check for a carrier settings update.
Update your iPhone to the latest version of iOS.
Make sure that your voicemail is set up. You can check this by dialing your phone number from your iPhone.
Make sure that you have a good cellular network connection. You can check this by tying to make an outgoing call.
Call your iPhone from another phone and try to leave yourself a voicemail.
Reset your network settings by tapping Settings > General > Reset > Reset Network Settings.
Reset your voicemail password.
If you insert a new SIM card, you might lose the visual voicemails that are saved on your iPhone.
If it still doesn't work after, please notify:)
Hope this helps:)
