Voicemail help
  • 3
Is there a way to get a voicemail icon or widget on home screen with voicemail notification ?
Photo of ricardo Ferreira
ricardo Ferreira
  • 1,504 Points 1k badge 2x thumb
Posted 3 years ago
  • 3
You want a voicemail widget instead of the regular notification?
https://play.google.com/store/apps/de...
There are other ways too
Missedit and Zooper widgets let you create your own widgets.
ricardo Ferreira
I guess something like that , I want something that when someone leaves a voice mail all I do is click on voicemail icon and it calls
Photo of VarieZ
VarieZ
  • 926 Points 500 badge 2x thumb
When someone leaves a voicemail their should be an icon and just tap on it, enter your 4 Digit pin and press 1.
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
You should be getting a voicemail notification in the notification bar at top of your screen.     Just click on it and it will dial your Voicemail.
Photo of frananddave
frananddave
  • 992 Points 500 badge 2x thumb
I find there's a time delay between receiving the message and seeing the icon. Here's what works for me. Call my own number whenever a missed call indicator comes in... That way I can listen to the message if one was left.
Hope this helps,
Frances
