using up all my minutes on two phones
If I have 2 phones on the same bill with 50 text messages available on each, can I use, say, 100 messages on the first phone and none on the second without extra billing cost?
Photo of Terry Whate
Terry Whate
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
Unfortunately, no. Koodo does not currently offer "sharing" of rate plan features between lines.
Which plan is it? Is it grandfathered? All of Koodo's new plans include Unlimited messaging so they may be worth a look...
Photo of John Lee
John Lee
The new plans have been upgraded a lot. They now cover Caller ID, Voicemail and Unlimited texts, but however the minutes are now per-minute and not per-second. (depending on what grandfathered plan you had).
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
No. Koodo does not allow sharing between numbers for the text limit. Same goes for minutes and data but you didn't ask about those :P
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Theres new plans that include unlimited messaging, i suggest you take a look at those on the koodo website
Those plans also includ. Per minute billing, something to think about before changing plans. If you change from a plan that is no longer offered you won't be able to switch back.
