Using too much data can't reconnect to wifi forgot passwor
Photo of Annette Liles
Annette Liles
  • 174 Points 100 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
You can turn off data until you figure out your WiFi password. But we can't really help you with that unless we know your router model; we might be able to help you reset it.
Annette Liles
Ok thanks I will get back to u Wheredo I find the router model?
Photo of Rocky Balboa
Rocky Balboa
You should contact your internet service provider. They will walk you through logging in your router to verify your wireless name and wireless password. Most routers the gate way is 192.168.1.1 which needs to be typed from your internet browser. If it's default the username and password should be admin admin. Once your in there look for wireless settings or wireless look at the SSID (wireless name) and input a password after selecting WPA encryption.
It's usually on the back or bottom of the router
For instance my linksys router has a label on the bottom the model is WRT54G
Also check your router for the pushbutton configuration button
On newer devices you can easily setup a connection to your wifi using this button.
Here it is on the Q10
