Using Telus iphone 4s with Koodo Mobile
I have a telus iphone 4s. I have inserted my koodo sim card in it but it shows the sim is not valid.
It doesn't allow me to use the phone even after taking the sim card out.
Do I need to visit one of Koodo kiosk to get some help?
Do Koodo kiosks provide this kind of service (telus iphone 4s with Koodo sim card problem)?
Thanks,
Slee
Photo of Sueng Ho Lee
Sueng Ho Lee
  • 300 Points 250 badge 2x thumb
Where did you get this iPhone?
Does the sim work in other devices?
Sueng Ho Lee
I got it from my buddie who upgraded his phone to iphone 5s.
I have tried with my own sim card which is currently being used for Samsung galaxy mega from Koodo.
The sim card works great with my own device.
Photo of Daniel Kim
Daniel Kim, Mobile Master
hmm I'm stumped, maybe try updating your carrier settings then rebooting your phone, it's worth a try.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
This link might help.
How do I activate my iPhone?
http://help.koodomobile.com/plans-add...
Photo of Rocky Balboa
Rocky Balboa
It can what you have to do is insert your koodo sim card and resync your phone back to itunes. Make sure also you have the most recent version of itunes installed. When you do this the carrier settings will update in the phone automatically and it should work.
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
But, as we said recently, if your Koodo card doesn't work it means that the phone wasn't actually with Telus. Because usually, you just pop in the card and it works! Please confirm with your friend that the phone was with Telus and keep us posted!
Sueng Ho Lee
The phone is with Telus and it works with Telus sim card. I just inserted my friend's Telus sim card and there is no problem.....
Rocky Balboa
Did you try what I mentioned in the earlier post if so what was the error message or what happened?
Photo of Brian Mead
Brian Mead
  • 60 Points
I had same problem. I had to unlock phone to work.
Photo of koodotel
koodotel
  • 60 Points
SIM not valid indicates that your iPhone 4s is locked with your current network . First, of all unlock your iPhone 4s from carrier lock . you can use Remote unlocking method to unlock it . you can get it from any of the online vendors like http://www.theunlockspot.com/apple-ip... to unlock it .
Photo of Ivan
Ivan, Mobile Master
Spam.
