Using my iPhone5 abroad
Hi,
I have an iPhone 5 and I was wondering how would I be able to ONLY use wifi, and turn of everything else so I don't get charged anything while I'm traveling
Photo of kathryn
kathryn
Photo of Sophia
Sophia, Mobile Master
Sure you can, Kathryn. The very safest method would be to remove your SIM card for the duration of your trip, or you can set your phone to airplane mode and enable just WiFi. Wishing you safe travels!
Photo of Ivan
Ivan, Mobile Master
If you keep your SIM card in the phone, you can disable mobile data on the app level as well:
http://support.apple.com/kb/ht4146
