Using LG9100T
I would like to set up a phone for my wife using a LG9100T previously used at Telus. Will this work on Koodos system.
Photo of Allan Ell
Allan Ell
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Does the LG9100T use a SIM card Allan? I think it is an older CDMA device, and in that case, I'm afraid it can't be used on any carrier except Telus... and they are phasing that system out as well :( You might consider another phone for your wife... do you need suggestions?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,992 Points 100k badge 2x thumb
It is indeed a CDMA device.
