Using a prepaid SIM with a device other than a phone
I am trying to use a prepaid SIM in a device that is not a phone (a PLC that can send/receive SMS); however, I have registered the prepaid SIM with a phone before transfering to the PLC. Is it possible for the SIM to work with this device? So far no luck.
Photo of Sean Stewart
Sean Stewart
  • 90 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
I'm not really sure. The device has to be compatible with the network frequencies otherwise it won't work.
Sean Stewart
All I know is that it's operating via GSM. Based on my failed attempts to get it working thus far, I'm going to go ahead and assume that Koodo doesn't support GSM?
Photo of Jonathan I
You got it. Only Rogers/Fido have GSM. Koodo (Telus) uses HSPA 850/1900 and LTE 1700/2100
Sean Stewart
I definitely should have checked this before hand ;P
Thanks for the help!
