Using Québec no. In alberta
  • Updated 5 months ago
Hi im with unlimited making calls and texting all over canada just curious to know if im able to use this facility in Alberta as im moving there? Pls guide
Photo of adarsh Jassal
adarsh Jassal
  • 74 Points
Posted 5 months ago
Photo of Dennis
Dennis, Mobile Master
  • 196,006 Points 100k badge 2x thumb
Texts, yes since they are canada wide.
If you have Canada wide calling when in Quebec, then yes you can make and receive calls in Alberta without issue
Photo of Allan
Allan, Mobile Master
  • 62,070 Points 50k badge 2x thumb
Note that you may have to switch to an Alberta plan in the future.
Photo of Dennis
Only if you switch to an Alberta number
Photo of Allan
Oh okay, the nitty gritty says otherwise, or is just vague with the details.
"Rate plan available for Quebec residents with Quebec area codes only. Subscribers moving to another province will be transferred to an applicable rate plan for that location."
Photo of Dennis
If you dont change your address or phone number, no one will know ;)
Photo of Allan
You beat me!
Photo of BobTheElectrician
BobTheElectrician
  • 67,194 Points 50k badge 2x thumb
The voice of experience: one couple I know moved from QC to ON three years ago. He kept his QC number & plan, she switched to an ON number & plan, so between them they have a local number for both sides of the family to use.
Plan and billing goes with the area code of the number.
