Using positive tab balance to upgrade phone, but keep old plan?
  • 2
  • Updated 2 years ago
I like my current plan and do not want to change to one of the newer plans. I have a positive Tab balance (almost at $150), and would like to use that to upgrade my phone using the SIM only option (pay for it outright without the new tab). Is this possible?
Simplified Example: I want to upgrade to the Nexus 5 ($360 SIM Only/No Tab), but I'd like to use my current $150 positive tab balance (on tab small) to bring the price down to $210, while keeping my current plan (and tab small, i guess?)
Photo of Ryan Lagace
Ryan Lagace
Posted 3 years ago
  • 2
Photo of Kakarot
Kakarot
  • 1,194 Points 1k badge 2x thumb
Unfourtantly the old days of TAB small, medium, and large are gone of you want to put money against your tab (create a negative balance) you will have o switch to one of the new plans. If you want too keep your current plan you can use your positive balance towards the cost of a new phone and then pay the difference.
Example: Nexus 5 $360 - $150 positive balance = keep your plan and pay $210
Hope this helps. :)
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
Note that if you have the 10% discount and you use ONLY your positive tab balacne ( or even buy a Koodo phone at cost outright) you will lose the 10% discount
Ryan Lagace
I currently get the 15% contribution to my tab - will that go away when i upgrade my phone, and keep my current plan? Also, if i refer a friend for 25 tab credits, will that still be applied if my current tab (tab small) goes away?
Photo of Dennis
Yes that will go away when you get a phone. But the max positive tab you can get is $150 anyways.
Your Referral credits are applied to your Tab (up to a positive tab of $150).
So if you are at positive $150 tab right now you need to use it before the referral tab is applied or you lose it since you can only have a max of $150
Photo of Melina Stanko
Melina Stanko
  • 92 Points 75 badge 2x thumb
Hi,
  I know this is an old thread, but I wanted to put this somewhere where my question would be relevant (instead of starting a new thread).
  My current phone is an old iPhone 4S, and I would like to upgrade (the phone still functions fine, and I have no doubt that it could go for another 2 years; but, the OS/Camera occasionally freeze and crash, and I figure that I should probably upgrade).
  The plan I have is an old one, but I have a positive tab balance of $150.
- The price of the phone that I want, iPhone 7 256G, is $630.
- I want to pay the $630 in cash.
  So, this is my question: How do I use my tab when I do not want to carry a tab balance on this new phone (I bought the other one outright from Apple)?.
  Is it even possible for me to be able to use my Tab and not carry a tab balance?.
  Thank you so much for your time :)
